M-981
KitMaker: 6,042 posts
Armorama: 4,347 posts
Posted: Wednesday, May 22, 2002 - 09:24 AM UTC
Hi peeps hope the sharing animal is loose amonst you all. Has anybody ever built the M-981 Fist from Academy,if so any pointers you can supply would be appreciated have detail set for it.
Thanks
Jeff
Sabot
KitMaker: 12,592 posts
Armorama: 9,067 posts
Posted: Wednesday, May 22, 2002 - 10:33 AM UTC
I noticed Squadron had the Verlinden conversion on sale for $9.99 and don't know if any of those details would help out the Academy kit. I do have a FIST-V at work as well as a couple of the turret trainers.
Posted: Wednesday, May 22, 2002 - 04:59 PM UTC
Looks like a pretty good kit out of the box I did get the eduard detail set for it Rob. Not to many pics of it on the web,but will keep trying.
Latter
Jeff
Posted: Wednesday, May 22, 2002 - 05:27 PM UTC
Did find these two good sites
http://www.fas.org/man/dod-101/sys/land/m981.htm
http://community.webshots.com/album/34237122WNPxRv
latter dudes
Jeff
Have a Happy memorial day if anybody can be Happy on this day
KitMaker: 17,418 posts
Armorama: 13,529 posts
Posted: Wednesday, May 22, 2002 - 07:07 PM UTC
The Academy FIST-V is pretty accurate. I think it is better than the Verlinden conversion, which had some severe fit problems. About the only thing missing are round guards around the rear antenna bases. To replicate these, I use small drinking straws cut to about 1/4 inch long, then cut out squares so it looks like two rings, upper and lower connected by four vertical bars positioned at 12, 3, 6, and 9 o'clock positions when viewed from the top. Also, the sight unit in the target head is not correct for a FIST-V, it is a TOW sight. It is best to leave it out, you cant tell there is anything in there anyway. The actual vehicle has a G/VLLD (Groung/ Vehicular Lasar Locator and Designator) in the target head. Of note, this vehicle is being replace in the active army by the M-7 B-FIST (Bradley- Fires Integration Support Team) Vehicle. Basically a M2A2 bradley that looks externally the same as a normal brad with the addition of two antennas on the rear light shrouds simmilar to the M-981. All the FIST improvements are in the targetting system and fire support computers inside. You can also see the M-7 B-FIST at FAS website. Hope this helps.
m60a3
KitMaker: 778 posts
Armorama: 396 posts
Posted: Wednesday, May 22, 2002 - 09:45 PM UTC
Good info, HeavyArty. Thanks for the post! And welcome to Armorama.
Posted: Thursday, May 23, 2002 - 02:37 AM UTC
Thanks guys I think we will have enough to get that puppy together about christmas time as their is a lot to do between now and then. but I like to have my info up and going so I can print what I need and study study until it is time to build,to me saves time instead of cracking it right out and say ooh goosh that ain't right.
Latter and have a good Memorial day Gents may the model gods smile upon you all and may God smile upon us you.
Jeff
