User Support
Having a problem with the site? Post it here.
Multiple Page Logon Issue
justsendit
KitMaker: 2,637 posts
Armorama: 2,156 posts
Posted: Friday, November 03, 2017 - 03:57 AM UTC
Jim,
I've been doing some rigorous testing and it appears that logging onto multiple pages is working correctly now. Thanks for all that you guys do.
Cheers!🍺
ómike
staff_Jim
Staff MemberPublisher
New Hampshire, United States
KitMaker: 12,411 posts
Armorama: 6,572 posts
Posted: Thursday, November 02, 2017 - 08:09 PM UTC
Yes this is all connected to the HTPPS update I did recently. I need to convert all the typical links to network (*.kitmaker.net) links rather than the standard domains.
Thanks for pointing this out. Basically when you are on any of our sites now and go to login they are not going to let you login to the standard domain. Rather you will be logged in with a kitmaker.net cookie as that is one of the two sites I have an SSL certificate for, etc.
Jim
justsendit
Posted: Thursday, November 02, 2017 - 02:55 AM UTC
Hi Mike,
Can you give me a URL of a page you are seeing this on?
Once you are logged in, you shouldn't need to login again.
Thanks,
Jim
Jim, The issue is most noticeable when linking from an e-mail subscription such as below.
https://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=220419
Cheers!
ómike
Edit: I just received an e-mail notification with this link which worked fine:
https://armorama.kitmaker.net/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=220419
I suspect that youíve updated the link to open through KitMaker. Am I right?
tatbaqui
Staff MemberNews Writer
#040
Metro Manila, Philippines
KitMaker: 2,612 posts
Armorama: 2,353 posts
Posted: Thursday, November 02, 2017 - 02:44 AM UTC
I've changed my bookmarks to the secure sites -- Armorama and Kitmaker. Logging on direct to Armorama however has this issue as described by Mike. Best to go in via Kitmaker -- no issues encountered, and one logged-in, it gets you to all sites as well as the gallery.
staff_Jim
Posted: Thursday, November 02, 2017 - 12:49 AM UTC
Hi Mike,
Thanks,
Jim
Maki
Staff MemberSenior Editor
Croatia Hrvatska
KitMaker: 5,258 posts
Armorama: 2,713 posts
Posted: Wednesday, November 01, 2017 - 11:32 PM UTC
I think this is the issue with the new https protocol instead of the earlier http Armorama was running. I had the same problem as I had bookmarked http://armorama.com and every time I opened the site through that particular bookmark I got the same message as you did. But when I added https://armorama.com version to the bookmarks instead, everything works well.
Mario
#406
KitMaker: 10,313 posts
Armorama: 8,160 posts
Posted: Wednesday, November 01, 2017 - 10:57 PM UTC
If you log on to the Kitmaker Network you will automatically be logged into every other site on our network.
Removed by original poster on 04/24/18 - 11:21:32 (GMT).
