Dioramas: Buildings & Ruins
Ruined buildings and city scenes.
Syria dio
zorrolobo
Distrito Federal, Mexico
KitMaker: 1,403 posts
Armorama: 1,389 posts
Posted: Wednesday, April 18, 2018 - 10:51 PM UTC
Working on a ruined building for the dio:
That is the ground floor.
upper floor:
I am not sure about the latticework on the balcony. What do you guys think?
zorrolobo
Posted: Wednesday, April 18, 2018 - 11:10 PM UTC
Some pictures where you can see the structure better:
Next I will apply the Vallejo white stucco tu the upper floor and work on the ground floor windows.
zorrolobo
Posted: Sunday, April 22, 2018 - 10:53 PM UTC
I have decided to go with iron for the balcony banister. Something like this:
JGphins
KitMaker: 233 posts
Armorama: 233 posts
Posted: Monday, April 23, 2018 - 12:05 AM UTC
Hello Marcos, nice project you got going here. I like the clay and plaster look that the cork material provides. I might have to consider utilizing this material in the near future to help in achieving these faster and easier results. Looking forward to the progress. Thanks for sharing.
JGphins
strongarden
KitMaker: 730 posts
Armorama: 624 posts
Posted: Monday, April 23, 2018 - 07:13 AM UTC
Wow Marcos, this is really coming along great! Looking frwd to the finish.
The techniques used for the bldgs are smart and simple, and have yielded excellent results.
Saludos amigo
Dave
zorrolobo
Posted: Monday, April 23, 2018 - 08:01 AM UTC
Thank you Joaquin and Dave.
KitMaker: 1,311 posts
Armorama: 1,303 posts
Posted: Monday, April 23, 2018 - 07:10 PM UTC
Looking very promising, I really like the different textures, hope you can preserve them. Definitely very fine wire or brass for the balconies - lots of fun bending/damaging them
zorrolobo
Posted: Monday, April 23, 2018 - 09:26 PM UTC
Thank you Tim.
Here is the new banister:
KitMaker: 7,731 posts
Armorama: 7,725 posts
Posted: Monday, April 23, 2018 - 10:23 PM UTC
Fits in nicely. Looks the part !
KitMaker: 941 posts
Armorama: 767 posts
Posted: Tuesday, April 24, 2018 - 02:09 AM UTC
Very nice. How did you do the rings?
maartenboersma
Noord-Holland, Netherlands
KitMaker: 725 posts
Armorama: 703 posts
Posted: Tuesday, April 24, 2018 - 02:39 AM UTC
zorrolobo
Posted: Tuesday, April 24, 2018 - 06:05 AM UTC
Thank you Jerry, Ryan, and Marteen. And Ryan, It is very easy to do the rings. All you need is copper wire; the thickness depends on how thick you need your rings to be. And a piece of sprue:
With the copper wire make a coil around the sprue
Remove the coil from the sprue
Cut the coil
take one loop
With pliers flaten the loop and reshape it into a ring
Make as many as you need. And that's it Ryan. Hope it helped.
KitMaker: 941 posts
Armorama: 767 posts
Posted: Tuesday, April 24, 2018 - 06:25 AM UTC
Great demo, thanks.
zorrolobo
Posted: Tuesday, April 24, 2018 - 10:57 PM UTC
Playing a little with possible layout of dio:
JGphins
KitMaker: 233 posts
Armorama: 233 posts
Posted: Wednesday, April 25, 2018 - 02:10 AM UTC
Good progress to building Marcos & nice touch in creating the rings, it adds character. Keep up the good work.
drabslab
KitMaker: 2,174 posts
Armorama: 182 posts
Posted: Wednesday, April 25, 2018 - 04:45 PM UTC
Very nice dio!
However, it strikes me that almost every dio with buidlings I have ever seen has that building on the side, and not in the center.
A dio with a complete building (run) occupied by ... including maybe even some AFV might be a nice change... Not that I have any relevant experience as I never build any dio worth that name
zorrolobo
Posted: Wednesday, April 25, 2018 - 11:55 PM UTC
Thank you Joaquin and drabslab. Buildings or structures in dioramas are usually scenography to create a "stage" (a "scene") where you want to tell a little story. Your models, both vehicles and figures tell the story.
zorrolobo
Posted: Friday, April 27, 2018 - 10:48 PM UTC
How the broken structures were made:
Starting with the paint:
Posted: Tuesday, May 01, 2018 - 06:44 PM UTC
Brilliant solution to the concrete and rebar floor. But wouldn't those parts be hanging down because of the huge weight ? I recall seeing alot of destroyed buildings looking like that ?
Great job so far though,
zorrolobo
Posted: Tuesday, May 01, 2018 - 09:02 PM UTC
You are right Jerry, they will be hanging. But I left them "up" while I work inside the interior. It is just a lot simpler if they are not in the way. But thanks for the observation.
zorrolobo
Posted: Tuesday, May 01, 2018 - 11:42 PM UTC
some advance:
strongarden
KitMaker: 730 posts
Armorama: 624 posts
Posted: Wednesday, May 02, 2018 - 02:41 AM UTC
It's always fascinating to me how there's a good handful of fellows on here that can take cork, blue insulation foam, or plaster and carefully carve out beautiful brick walls and stoneworks.
Looks great Marcos, cheers
Dave
zorrolobo
Posted: Wednesday, May 02, 2018 - 09:44 PM UTC
Thank you Dave! Cheers!
Posted: Thursday, May 03, 2018 - 07:47 PM UTC
Great work Marcos it looks dead right/in scale so it should all fall into place (excuse pun) when the rubble’s piled up under the sagging chunks
KitMaker: 2,074 posts
Armorama: 1,702 posts
Posted: Friday, May 04, 2018 - 07:21 PM UTC
Nice work Marcos , this is turning out very , very cool !!!
