Bridge on River Kwai
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Saturday, October 27, 2018 - 12:53 AM UTC
Have started building a 1/150 scale model of the Bridge on the River Kwai. It is the movie bridge and not the real one. It is a scratch build, and a work in progress. The model will be set in a small diorama, depicting the conditions in which the Prisoners Of War (POWs) were in at that time.
Rough Plan to get idea of the overall build.
Width is 160 mm
to be continued . . .
KitMaker: 868 posts
Armorama: 866 posts
Posted: Saturday, October 27, 2018 - 01:12 AM UTC
“Madness….madness”
https://www.youtube.com/watch?v=zpl4wkWMJtE
fantastic project, very best of luck (& if you need any help with demolition I’m not too far away)
obg153
KitMaker: 877 posts
Armorama: 863 posts
Posted: Saturday, October 27, 2018 - 02:02 AM UTC
WOW!! What a challenge, and definitely worth following your progress. Will you have figures as well?
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Saturday, October 27, 2018 - 02:04 AM UTC
Thanks Tim Martin for encouragement.
"Luck often enough, will save a man, if his courage holds" - Buliwyf (13th Warrior)
KitMaker: 7,052 posts
Armorama: 7,046 posts
Posted: Saturday, October 27, 2018 - 02:31 AM UTC
Awesome concept for a dio. This movie fascinated me when I was a kid and saw it on TV.
Good luck and post pics please.
deathdork
KitMaker: 238 posts
Armorama: 226 posts
Posted: Saturday, October 27, 2018 - 04:59 AM UTC
Amazing project. Looking forward to this one. Curiosity asks if you intend to build the full span?
Robbd01
#323
KitMaker: 734 posts
Armorama: 315 posts
Posted: Saturday, October 27, 2018 - 06:03 AM UTC
I tried building that bridge using toothpicks. I think the old Magnum P.I. TV series in the '80's, the Higgins character was building one.
Cheer
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Saturday, October 27, 2018 - 08:23 AM UTC
Yes.
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Saturday, October 27, 2018 - 08:26 AM UTC
If you mean, do I intend to build as per above drawing, my answer is yes.
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Saturday, October 27, 2018 - 08:30 AM UTC
Cheer
Some other model builder built the bridge for the TV set. I think he built three versions. One was blown up.
There was also two manufacturers (as far as I know) that made a 10 piece kit at similar scale. However, I prefer to do a scratch-build version.
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Saturday, October 27, 2018 - 09:04 AM UTC
Because this model is a tribute to the POWs who were on the Thai-Burma Death Railway, this WIP will also include links and images for historic reasons.
https://en.wikipedia.org/wiki/Burma_Railway
https://anzacportal.dva.gov.au/history/conflicts/thaiburma-railway-and-hellfire-pass
I have to tell you that my research into this build has revealed many constant images of savage enslavement and death. It is depressing. So, to counteract this, I have introduced some lighter entertainment into the build images, by using one of the 1/150 plastic figures. He is called 'Minder'. He keeps my mind on even ground, minds what I am building (like a foreman), reminds me of scale size, and the tribute.
_____________
Experimented with these plastic figurines. They all look too healthy for POWs so I tried to whittle them down to size.
Came across other plastic figurines at 1/150 scale, on eBay, that looks a lot thinner. Have ordered them in.
To start with a base, I used 12 mm scrap plywood. Went to hardware store and bought 4 and 6 mm dowel wood (Tasmanian Oak).
Here Minder is telling me to get the dowels off the base so I can start drilling holes for the piers. Also started cutting the piers sizes too (according to an improved drawing of the bridge).
mudcake
South Australia, Australia
KitMaker: 48 posts
Armorama: 45 posts
Posted: Saturday, October 27, 2018 - 11:42 AM UTC
https://www.youtube.com/watch?v=d4AqAbw3kTQ
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Saturday, October 27, 2018 - 01:49 PM UTC
Happy with 'my work'? Yes.
Happy with 'the work'? No.
Honoured? Yes.
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Saturday, October 27, 2018 - 01:53 PM UTC
The piers are tapered to represent tree trunks.
Minder got buried in his work.
Kept sanding dust, to be used as sawdust in diorama scene.
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Saturday, October 27, 2018 - 08:13 PM UTC
All they got for food was one scoop of rice and water per day. That's it!
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Sunday, October 28, 2018 - 09:15 AM UTC
The original base has a bow in it. To counteract it I added another base, of same source, with opposing bow. So, the base is now called a platform, and the new (larger) base will become the display case base.
Glued the boards together. Later, I added screws too.
Minder, with poor safety sense, is guiding my saw cut.
Display case will include 3 mm clear Perspex surround. Used scrap Perspex, plus thin card, to gauge a gap for the surrounding frame. Don't have a saw angle jig, so I made a few errors in getting the correct side for a 45 degree cut.
Minder noticed I drilled extra column of holes at both ends of bridge.
On applying wood putty, the relatively new spatula broke. Lucky I still kept my old one.
After some sanding.
strongarden
KitMaker: 672 posts
Armorama: 567 posts
Posted: Sunday, October 28, 2018 - 11:32 AM UTC
Nice project and dedication Peter, Im following!
Regards
Dave
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Monday, October 29, 2018 - 08:17 AM UTC
Thank you Dave (strongarden) for visiting this build and following,
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Monday, October 29, 2018 - 08:34 AM UTC
Figuring out how this bridge was put together. Quickly realized that it was a slapped together in a round about way. After all, the whole movie bridge was meant to hold the weight of a train and carriages, and then blow it all up.
Looking for an appropriate construction method, with available materials, for this model. Below, the drawing got altered later on (improved).
Re-drilled the outer holes at a slight angle to assist in the lean-in of the piers. Used a dressed piece of timber as a template for aligning outer piers.
Top left: the improved drawing, as mentioned earlier.
To assist in leaning the piers inward, I had to whittle part of the dowel portion that goes into the platform. The shavings got saved for other parts of the diorama.
One step back to far.
KitMaker: 6,012 posts
Armorama: 4,338 posts
Posted: Monday, October 29, 2018 - 12:00 PM UTC
Nice so far, a big undertaking.
Will keep looking in.
Jeff
JPTRR
RAILROAD MODELING
#051
KitMaker: 7,340 posts
Armorama: 2,273 posts
Posted: Monday, October 29, 2018 - 12:42 PM UTC
Awesome! Looking forward to this!
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Monday, October 29, 2018 - 01:56 PM UTC
Jeff
Thanks Jeff for visiting this build.
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Monday, October 29, 2018 - 01:58 PM UTC
Thanks Frederick Boucher for kind words.
TEACKO
KitMaker: 42 posts
Armorama: 41 posts
Posted: Monday, October 29, 2018 - 02:02 PM UTC
last week, Jack, an old friend, was telling me his father was one of the Australian POW along the Burma Railway. One of the stories was how he witnessed five POWs fight tooth and nail over a dead rat.
Blaubar
Rheinland-Pfalz, Germany
KitMaker: 261 posts
Armorama: 246 posts
Posted: Monday, October 29, 2018 - 10:31 PM UTC
This is amazing, love it. I have been there 3 years ago... The rebuilt steel one is still standing after the reconstruction in the later 40s.
/Stefan
