Tamiya 35227 - metal track options?
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Thursday, May 16, 2019 - 09:19 AM UTC
Could not find a search function on this forum (getting older and dumber!).
searched internet - no luck.
Any suggestions for metal tracks for Tamiya's 35227 Afrika Tiger I?
Thank you in advance!
sdk10159
Oregon, United States
KitMaker: 552 posts
Armorama: 430 posts
Posted: Thursday, May 16, 2019 - 10:01 AM UTC
Have you tried Fruil ATL-06?
PanzerKarl
KitMaker: 2,307 posts
Armorama: 1,856 posts
Posted: Thursday, May 16, 2019 - 10:22 AM UTC
Thought ATL-25 would be more sufficient or even ATL-116 mirrored tracks
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Friday, May 17, 2019 - 09:36 AM UTC
The package for the Fruil ATL-06 says "Tiger I middle - late"
Tamiya 35227 is an Afrika (early) Tiger I... will the Fruil ATL-06 fit the Tamiya 35227 (I am new to this)?
Thank you for your reply
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Friday, May 17, 2019 - 09:38 AM UTC
These are for early Tiger I
Thank you very much
I think I'm catching on... slowly!
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Friday, May 17, 2019 - 09:41 AM UTC
Another question
Friul tracks require assembly
and apparently modification (drilling, and possibly
the replacement of the pins provided)
All of this is currently not possible for me
Are there metal tracks that are pre-assembled,
or at least that do not require modification
to be replaced
Thanks in advance.
ps - respect to all those who have the skills
to make those Friuls work...
your finished products are terrific!
mpeplinski
Michigan, United States
KitMaker: 487 posts
Armorama: 182 posts
Posted: Friday, May 17, 2019 - 10:05 AM UTC
http://www.hobbyworld-usa.com/Store/index.php?id_product=3681&controller=product
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Friday, May 17, 2019 - 10:15 AM UTC
Looking at Warp United metal tracks
they require assembly
can they be assembled without
modification
Thanks in advance
Tojo72
KitMaker: 4,507 posts
Armorama: 3,388 posts
Posted: Friday, May 17, 2019 - 10:19 AM UTC
Another question
to be replaced
Thanks in advance.
Fruils do not require modification,some require the holes bring cleaned out with a thumb drill,and pins are not a necessity as the supplied wire works fine.
I apologize if for some reason you can't physically handle them,but really I am surely no expert,they require no special skills.
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Friday, May 17, 2019 - 10:27 AM UTC
[quote]
Thanks for the reply
I am new to this - do not know what a thumb drill is
(just googled it!)
Accordingly, I feel I must apologize for asking so many questions given my currently weak knowledge base
Thanks again
and thanks to all for your patience!
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Friday, May 17, 2019 - 10:28 AM UTC
Awesome!
Considering these strongly
Thank you!
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Friday, May 17, 2019 - 10:35 AM UTC
Just ordered these!
Thank you very much!
Yay!
Question - do these require washing, etc before painting;
if so, how?
eoin666
KitMaker: 37 posts
Armorama: 35 posts
Posted: Friday, May 17, 2019 - 10:39 AM UTC
Nicola
Due to the nature of casting, the odd link might need the pre-cast holes cleaning out with a mini drill 0.5mm I think, it's very soft white metal so not a problem. The kits come with a length of wire which you cut into appropriate lengths for the width of the links and insert from one side, then a spot of superglue to fix. Out of all after market tracks they're probably the easiest, even if not the cheapest.....sit in a comfy chair with a tray on your lap, favourite TV show on, and favourite drink at the side!!
No, they can be blackened with acids if you wish, but easy enough to paint as usual, maybe give them a metal primer coat first
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Friday, May 17, 2019 - 01:59 PM UTC
Nicola
I know nothing about how to do this
Can you recommend tools/brands, etc please
I chose the Master club tracks because they looked the easiest!
Thanks in advance
Thirian24
KitMaker: 2,489 posts
Armorama: 2,340 posts
Posted: Friday, May 17, 2019 - 03:52 PM UTC
For ease of building metal tracks, you might take a look at Easy Metal Links tracks. Unfortunately I have yet to see them release a set for a Tiger, but they have a lot for Pz. III and Pz. IV, they go together super easy. I know this doesn't help on your current build, but maybe a future one.
Here is a video of how they are assembled.
https://m.youtube.com/watch?v=-SD2c8jutqE
ericadeane
KitMaker: 3,950 posts
Armorama: 3,879 posts
Posted: Sunday, May 19, 2019 - 07:11 AM UTC
Searching for related accessories can be accomplished easily here:
www.scalemates.com
KitMaker: 1,289 posts
Armorama: 1,229 posts
Posted: Monday, May 20, 2019 - 12:40 AM UTC
With Friule track I get some standard staples. I bend the staple from a "U" shape to an "L" shape. I then push the long straight side through the track using the shorter side to push with. When I am done I come back and clip off any excess that protrudes. If I want to blacken the track I wash it with soap and water using a toothbrush first then use the blackening liquid. If I want to paint them, use a metal primer first.
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Wednesday, May 22, 2019 - 10:56 AM UTC
Thanks to all for your replies.
I ordered the Masterclub metal tracks.
Again, thanks to all for your replies!
noobking
KitMaker: 25 posts
Armorama: 25 posts
Posted: Wednesday, May 22, 2019 - 10:57 AM UTC
Very Cool!
