how would you fill this?
flyers42
KitMaker: 62 posts
Armorama: 60 posts
Posted: Tuesday, October 08, 2019 - 11:05 AM UTC
Im running into alot of these mold circles from an old Tamiya kit, how would you fill them?
flyers42
KitMaker: 62 posts
Armorama: 60 posts
my picture didnt work
flyers42
KitMaker: 62 posts
Armorama: 60 posts
Posted: Tuesday, October 08, 2019 - 11:11 AM UTC
flyers42
KitMaker: 62 posts
Armorama: 60 posts
Posted: Tuesday, October 08, 2019 - 11:12 AM UTC
ok there it is
ChurchSTSV
KitMaker: 350 posts
Armorama: 19 posts
Posted: Tuesday, October 08, 2019 - 11:14 AM UTC
Some people on here have these pens filled with fiberglass points that allow you to get into tight places and do some sanding.
Someone will pop up with the name of the tool. I would use that and just sand it away.
Klaus-Adler
MODELGEEK
Scotland, United Kingdom
KitMaker: 1,352 posts
Armorama: 747 posts
Posted: Tuesday, October 08, 2019 - 11:26 AM UTC
I've never heard of those so I hope some one does tell us about them.
Kenaicop
#384
KitMaker: 1,363 posts
Armorama: 1,260 posts
Posted: Tuesday, October 08, 2019 - 11:40 AM UTC
Fiberglass Pens
https://www.amazon.com/s?k=fiberglass+pens&gclid=EAIaIQobChMI37TVkuuN5QIVERx9Ch13uA9vEAAYASAAEgLiE_D_BwE&hvadid=329742114125&hvdev=t&hvlocphy=9030819&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=11782075229787596989&hvtargid=kwd-301732647584&hydadcr=8431_9886304&tag=googhydr-20&ref=pd_sl_serl0ts3x_e
d6mst0
#453
KitMaker: 1,707 posts
Armorama: 593 posts
Posted: Tuesday, October 08, 2019 - 11:42 AM UTC
A set of jeweler files comes in handy for this type of problem.
KurtLaughlin
KitMaker: 2,319 posts
Armorama: 2,294 posts
Posted: Tuesday, October 08, 2019 - 12:07 PM UTC
I use a punch set to make disks out of .005 or even .010 Evergreen sheet and glue them in place. Not surprisingly punch sizes correspond to the standard ejector pin sizes, so it's usually an excellent fit. These can be sanded down flush without changing the surface contour, unlike filling with putty or sanding them out.
KL
JPTRR
RAILROAD MODELING
#051
KitMaker: 7,623 posts
Armorama: 2,386 posts
Posted: Tuesday, October 08, 2019 - 12:54 PM UTC
Some people use gap-filling superglue. With the right touch, the CA gob will fill the ejector circle level with the edge. Some people use Future floor wax s it is self-leveling. Sometimes both products have a wee bit of baking soda mixed in so it doesn't settle in the middle, IIRC.
MLD
Vermont, United States
KitMaker: 3,541 posts
Armorama: 2,052 posts
Posted: Tuesday, October 08, 2019 - 01:34 PM UTC
Gap filling superglue, or make some sprue goo (old sprues dissolved in liquid glue), or Mr Surfacer 500 (liquid).
Headhunter506
KitMaker: 1,547 posts
Armorama: 1,481 posts
Posted: Tuesday, October 08, 2019 - 01:46 PM UTC
Using baking soda mixed with CA is a bad idea. First of all, baking soda absorbs moisture; and, second, this combination has been documented to react adversely with the underlying styrene. Do as Kurt suggested or use two-part epoxy putty, such as Magic Sculpt to fill in the ejector pin marks. Magic Sculpt doesn't shrink when cured and can be smoothed with a wet chisel blade so it is level with the surrounding plastic. Here is a link to a thread showing what CA and baking soda can do to a model:
Superglue and Baking soda
KitMaker: 1,571 posts
Armorama: 1,037 posts
Posted: Tuesday, October 08, 2019 - 02:00 PM UTC
First of all is it gonna be visible when the kit is fully assembled? For one that shallow sprue goo, let it dry for a day then a micro chisel to level it since it's in a small area surrounded with raised detail. Deeper ones gap filling superglue then careful knife and chisel work.
Headhunter506
Posted: Tuesday, October 08, 2019 - 02:01 PM UTC
The sprue/glue mixture has its own issues such as it takes an extremely long time for the liquid glue to evaporate. The remaining goop is never as hard as the plastic was in its original, undissolved form.
Paulinsibculo
Overijssel, Netherlands
KitMaker: 1,291 posts
Armorama: 1,209 posts
Posted: Tuesday, October 08, 2019 - 02:22 PM UTC
You can fill an old injection needle with Tamiya putty.
Just cut off the sharp part and go ahead.
KitMaker: 3,425 posts
Armorama: 1,913 posts
Posted: Tuesday, October 08, 2019 - 02:23 PM UTC
I like to thin Tamiya putty 50:50 with Tamiya thin cement in a small nylon paint pallet dish, then using the supplied brush which comes with the glue (I have a bottle of Tamiya thin just for this purpose), put a drop of this mixture into the ejector pin mark. You can re-apply if necessary, to bring it up to the level of the edge. This mixture usually dries and is ready for sanding in 15-20 minutes. Punching a disk of styrene as mentioned above also works. To smooth the putty-cement mixture out when dry (if necessary) fold a piece of fine grit sandpaper over a wooden skewer or dowel that’s been sanded to a flat edge, and sand it along the edges of the filled area.
panzerbob01
Louisiana, United States
KitMaker: 3,099 posts
Armorama: 2,930 posts
Posted: Tuesday, October 08, 2019 - 02:42 PM UTC
Russ. You beat me to it!
Everything much as Russ said: Thin Squadron green putty (or Tamiya putty or...) with a thin cement to make a thin mud, put sufficient mud into the hole or void or "sink" to slightly over-fill it, let it dry (it dries pretty fast... ), and then attack the little hump or bump as needed with a blade, chisel, or sanding stick or... yes, sand paper wrapped across the end of a wooden chop-stick or piece of sprue or whatever to smooth it out and level it. IF you are quick and have a narrow blade (a small screw-driver, or a small square-end chisel blade is good), you may well be able to simply smooth your wet mud into the hole and form and level it from the start, and never actually need to go back and do any further finishing of the patch.
In some cases, I simply cut a little piece of 0.005 styrene sheet and make a "tin-can patch" and glue it over the sink-hole. It's NOT technically "accurate", but (aside from the reality that war-planes, cars, trucks, etc. have had little random metal plates or pieces riveted or welded on to fix holes, patch cracks, etc. for the past 100+ years) VERY FEW viewers will ever even notice, let alone KNOW, that that little square "plate" in that corner wasn't really there on the "real thing"...
Been my go-to fixes for these little visible sink-hole problems for decades!
Bob
nikon1
Kansas, United States
KitMaker: 619 posts
Armorama: 602 posts
Posted: Tuesday, October 08, 2019 - 03:36 PM UTC
Another option is to use Tamiya surface primer from the bottle and build up in layers and smooth using a cotton ball soaked with Isopropyl alcohol.
Charlie
Posted: Tuesday, October 08, 2019 - 07:20 PM UTC
A lot of puttys never get real hard either. Squadron green and white will remain a bit soft so will bondo glazing putty. 5 minute epoxy and other epoxys get hard, almost too hard to work in small areas. Sprue goo will get as hard as any large area that required gluing but it's easy to make and has decent working life.
pod3105
Waterford, Ireland
KitMaker: 452 posts
Armorama: 432 posts
Posted: Tuesday, October 08, 2019 - 07:33 PM UTC
Vallejo or Delux plastic putty would also work. Water soluble and a gentle rud with a cotton bud or even finger tip might be enough.
rfbaer
KitMaker: 1,826 posts
Armorama: 1,662 posts
Posted: Wednesday, October 09, 2019 - 08:55 AM UTC
I use a very small chisel blade (cheap optical screwdrivers with the blades sharpened work great) and remove material from around the pin mark. No fillers, no drying time, and with a little practice, it's quick. I have a bunch of those tools made up, and with the corners of the blade rounded, they work great in concave and curved areas too, like the inside of hatches.
KitMaker: 934 posts
Armorama: 761 posts
Posted: Wednesday, October 09, 2019 - 09:53 AM UTC
Is it possible that the real part is hollow, so filling the pin hole is no more correct and hollowing out the part would be more correct?
Also depending on the detail you desire, use the part as a template on thick card stock and cut out new brackets. Might easier then fixing the pin mark.
marcb
KitMaker: 1,148 posts
Armorama: 1,132 posts
Posted: Wednesday, October 09, 2019 - 09:55 AM UTC
I'd scrape it away with a curved x-acto blade.
KitMaker: 9,147 posts
Armorama: 8,391 posts
Posted: Wednesday, October 09, 2019 - 10:46 AM UTC
I like Ryan's idea above.
Also these brackets are in an area that will get splashed with a fair amount of thrown up mud. Just use some small bits of putty to "dirty them up!"
tankmodeler
#417
KitMaker: 3,123 posts
Armorama: 2,539 posts
Posted: Thursday, October 10, 2019 - 02:19 AM UTC
I usually fill those voids with curse words.
